P
Phil
right here we go a poll for your preference, simply either ring or radial. I am not starting a discussion on the pro`s or cons about it merely just a show of hands. we are all aware of the pro`s and cons of both
Discuss ring or radial in the Australia area at ElectriciansForums.net
Radials here too. Just wish the price of 4mm would come down!
Radials.......so why do I end up installing rings most of the time?
Dirty old habits die hard, plus if you pull two separate 20amp radials up onto the second floor for example buy the time you've wired the floor with the two radials your probably only a couple of meters away from making it a ring and putting it on a 32amp breaker then you just go into auto pilot I'm talking large houses
Reply to ring or radial in the Australia area at ElectriciansForums.net
