Hi all,
Hoping you can advise as i have no experience with electrics.
I’d like to purchase the Ring Pro Doorbell as below which needs a constant power feed - requirements on the site, 16-24 vac transformer.
Video Doorbell Pro - https://ring.com/video-doorbell-pro
I dont have an exisiting powered doorbell so have been searching for alternatives to having an electrician over to connect to the CU - which is too far from the front door.
I’ve found and orderd the plug in adapter below on amazon which states i can just plug it into the wall and power the bell
https://www.amazon.co.uk/gp/aw/d/B0...236_SY340_QL65&keywords=ring+doorbell+adapter
Do you guys think this is suitable? I receieved the item today, its made in china, not ce marked or anything - bit concerned about load/fuses and basically blowing up the bell or at worse the adapter.
If this isnt suitable is there a plug in alternative, really look for ease and avoid wiring to the CU which isnt viable. I have a plug socket very close ot the door which is why this is preferable.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
