Ring vs Radial | on ElectriciansForums
Discuss Ring vs Radial in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Which is it for you.......
  • Total voters
    72
kingeri
Yorkshire
Hello all. It's been a while since this was discussed. I've noticed that increasingly more and more folks are leaning towards radials for socket outlets, myself included. What's the general concensus out there? I still tend to use rings in kitchens, but again not always.
Depends on the use and layout of the building. I find generally radials are much easier to run but if access is good then put a ring in, especially in the heavier load areas if only using 2.5.
Nothing wrong with ring circuits, until B&Q get involved anyway
Radials are certainly easier for rewires where you want power on by the end of the day
Also me thinks this will be in the next review by IEE because the only 2 things left with parity to Europe the ring and the 13amp socket
to balance out this debate we need someone to champion the cause of rings and all their benefits.
it wont be me though , radials for the win !
I prefer ring finals - why restrict the current to 20A when you can have 32A, or struggle with getting two 4mm cables in?
I don't understand it when people start talking about radials like they're some cutting edge technological breakthrough.
Rings were introduced after the war because copper was in short supply.
While it may not be in short supply as such nowadays, it's quite expensive and few people have money to throw around at the moment.
^^^ exactly, so why run an RFC to say two bedrooms of a small terraced house. You'll be using more cable and no way are they going to ever have problems with a radial, even one rated at 16 amps.
and at the time of invention it was common practice to just fit 1 ring for the whole house due to the small domestic loads of 1950's.
hardly a reason to still be using them 60 years later.
i can see this thread going on for a loooong time lol.
Well yes small loads in 1950 but now we are going the same way ie each light point was designed for 100W but that is now a 23w CFL lamp plus TVs take less load . Only problem for the future is when we need to move over to electric heating as gas is used less
Reply to Ring vs Radial in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
Which truly is the Number 1 Best Tile Adhesive Brand? Since 2007 Tilers Forums started an annual best tile adhesive Poll and sent it out to the...
