Ring wired doorbells (again!) | on ElectriciansForums
Discuss Ring wired doorbells (again!) in the DIY Electrical Advice area at ElectriciansForums.net
Tomtecno
Scotland
I’m trying to install my Ring doorbell (2nd gen) and I’ve discovered that the transformer feeding my Freidland isn’t producing any power. I suspect that I connected the jumper lead between the wrong wires (thanks to Ring’s really confusing instruction!) so I now need to replace it. I don’t want the existing chime to work anymore so can I just power the Ring doorbell directly from a new transformer and if so, what rating transformer will be best?
Hi, How did you install your doorbell in the end?
Reply to Ring wired doorbells (again!) in the DIY Electrical Advice area at ElectriciansForums.net
How about one of these ? No supply needed and has the benefit of having an array of different knocks for all types of moods.
Second Update: 12/25/2023 Hey everyone, so I solved my doorbell issue. Turns out there were two reasons why my doorbell wasn't turning on. 1.)...
