J
james king
how do u test to find a ring within a ring?
Discuss ring with in a ring in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You do the figure of 8 test, and take readings at each socket.
With a normal ring, each reading should be about the same, within 0.05Ω.
Where there are interconnections, the sockets between the figure of 8 connection and the interconnection will have a lower resistance than sockets after the interconnection.
Reply to ring with in a ring in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
