H
Hawk
How do you guys record a spur off a ring on a test certificate?
Discuss ring with spurs in the UK Electrical Forum area at ElectriciansForums.net
Yes it complies with the regs. Changed a fuse box and have to do an EIC so on the schedule of test results I was just wondering how to record an existing spur off a ring circuit.
I was thinking that a spur would give higher readings so was wondering if I should record these.
Ok. I have seen on other forums where people have said that say for instance a fused spur is taken off a ring for a lighting circuit. Then they would record the lighting circuit as a seperate circuit with 5amp 1361 as the fuse. Even though it is spurred off a ring.
Reply to ring with spurs in the UK Electrical Forum area at ElectriciansForums.net
