H
Hawk
How do you guys record a spur off a ring on a test certificate?
Discuss ring with spurs in the UK Electrical Forum area at ElectriciansForums.net
The origin of a circuit is at the DB/CU as stated in Appendix 15.
To start with, I would mention the situation in the 'comments on the existing installation' section of the report.
The spur should be unswitched, with a 5A fuse also labeled for 5A fuse max. The as for the lighting circuit should then fall within the allowed As for fuse in spur.
Don't know whether to do a number of lols, or perhaps a 'seriously?', just not too sure how to respond to something so obviously incorrect?It's hardly relevant quoting an Informative appendix which does not form part of BS 7671.
The people who suggest that a fused spur from a circuit would be a separate circuit are incorrect.
How is it a grey area?
It states quite clearly in BS7671 that the origin of a circuit is at the DB.
Is it just me, or do things become grey or open to interpretation, only when people want to swerve the Regs?
I'm with spinlondon on this. I understand that the appendices are informative and are not regulations themselves. But why do the do the authors put them in their book, if you are not act upon them or refer to them? Definition of appendices (Wikipedia); Generally, any text added to the end of a book or an article, containing information that is relevant to the main subject matter.It's hardly relevant quoting an Informative appendix which does not form part of BS 7671.
Reply to ring with spurs in the UK Electrical Forum area at ElectriciansForums.net
