ringmain testing | on ElectriciansForums
Discuss ringmain testing in the UK Electrical Forum area at ElectriciansForums.net
sparkie-leeds
Hi,
I have just tested an existing ringmain starting with the line conductor reading 0.32 and the neutral reading 0.87, these are both in 2.5 twin and earth, can someone explain why there is a big difference in the 2 readings when the conductors are the same size?
Looks like r1 is a little high too if your r2 is 0.28, its got loose connection written all over it or dodgy test leads mine gave me some funny readings the other day so I changed them now there perfect
Reply to ringmain testing in the UK Electrical Forum area at ElectriciansForums.net
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
