I have a small Pv farm 5KW. Some months ago inverter started to measure low Riso<1MΩhm (0.8). I tried to test each string alone and with one the inverter read good Riso and started normally. The other had very low Riso. I tried to check the two pv strings but both have same Voc 340Volts. So I think the ground fault may be in DC cable of the second string until inverter. How can I check it with the multimeter? In which way can I check the DC cable (~10m length)? In Ωhm position in multimeter which value should I see and how should I connect with the probes? With ground to one side or not?
