Mfctitch
Evening everyone
Have got hold of an robin kmp4120DL loop tester and need some advise.which has a three lead
When trying to carry out a PSCC test the manual says put the green lead on the neutral. but if I do put it on the neutral bar then put the probes on the incoming phase and neutral I just get a "HI" reading.
The only way to get a proper reading is to turn the main switch on which of course you are not supposed to do with the main cover off.
So I have two questions:
First what stupid thing am i doing wrong.
Second does any one know of any videos on the use of this and any of the other robin test meters.
Thanks in advance.
Thanks in advance.
