Robin Testers (x3) | on ElectriciansForums
Discuss Robin Testers (x3) in the For Sale and Wanted Forum area at ElectriciansForums.net
Spudnik
Righto chaps,
Having a bit of a clear out and i have decided to put these up for sale.
They/it is a Robin Test kit comprising RCD tester, earth loop tester & insulation/continuity tester.
They come with various test leads, although they are "used", and there some odds and ends in there as well.
Th meters themselves are a little gruuby, but will clean up with a bit of washing up liquid but, are in perfect working order with no snapped lids or straps.
They havent been calibrated for some time as they are my spare set, but I have checked them against my "in use" set and the readings are identical, however, it would be worth getting them done properly if you are considering using them full time.
They would make an ideal starter set for anyone just setting up, or even for practice etc.
This set comes in a soft carry case, although this is grubby, but the zips are fine! :D
[ElectriciansForums.net] Robin Testers (x3)
And no, the bread is not included.
Looking for around ÂŁ160 for the lot.
Collection only from South Hampshire.
Reply to Robin Testers (x3) in the For Sale and Wanted Forum area at ElectriciansForums.net
