My friend has got one of those robot lawnmowers that automatically goes out once a day and runs around the grass.
There is a single core guide wire buried around the perimeter of the lawn that must carry a signal that the mower senses and knows not to cross…
This wire has a break in it somewhere.
Is there an easy trick, or tool that can be used to find out how far along the wire the break is…. Or is it likely non repairable and needs replaced?
He’s already tried a continuity test with a simple multimeter, which showed an open circuit between the two ends…. But that might just be the lack of capability of a simple meter.
I could shove main voltage down it and see where the grass burns??? ️
