Rogue Landlord Encounters | Page 3 | on ElectriciansForums
Discuss Rogue Landlord Encounters in the UK Electrical Forum area at ElectriciansForums.net
KevinH
Pembrokeshire
Has anyone had encounters with rogue landlords?
I will tell my short story (and keep it as short as possible)
I had a call a few weeks back from a landlord to sort out an issue with an immersion heater following an "incident".
It seemed an emergency so I arrived that afternoon and the tenant, a middle aged Eastern European lady, let me in and explained (as best she could) that the landlord had fitted a plugtop to the immersion heater on the day she moved in to give hot water.
When I looked in the airing cupboard, I found an unrecognisable big black blob of melted mess that used to be a plug and socket where the 20A DP should have been. (Wanted to attached a pic, but it says the file is too large). After having a quick scan around the property, I noticed the tell tale signs of a rogue landlord. A pendant hanging from the ceiling supported by the cables, a cracked socket, no smoke alarms, and my favourite, a 3036 Re Wirable fuseboard. Not an RCD in sight!
I got straight on the phone to the landlord and explained the situation, of what had to be done, and completely unfazed, his reply was "can you just get the hot water back on and I will pay you cash", to which I replied "I can't do it today, I will have to return tomorrow".......
Ok, so I lied! I never had any intention of returning, as I have come across these type of landlords before who cut corners, totally ignore the safety of tenants and risk of a fire, and of course expect everything done for pennies...often not paying at all. I have not got the time of day for them!
Suffice to say that I informed Electrical Safety Roundtable, politely advised the tenant to find another landlord, blocked his number from my phone and walked away.
Should I feel guilty for leaving the lady with no hot water? How are these landlords getting away with it?
Echoing what others have said about this being a two-way street, years ago I had the contract on several postcode areas for a large lettings agent to do all their serviced work. The number of times I’d get called out for the simplest of things that were well within the capabilities and responsibilities of the tenants to resolve was unreal - replacing PP3’s in smoke alarms was such a common thing I kept bulk stock of them in the van. So the LL ends up with a £100 bill for the 30secs to change a £2 battery that requires no skills whatsoever!! The attitude of the tenant was literally ‘screw them, don’t care’.
However, this country has a major problem with housing stock and that has to be realised - it used to be the case that you finished studies/training, got a job, saved up and bought a house. But the gap between income, mortgage ratios and house prices just makes that impossible for so many. Basic maths says a couple each earning £30k gives a combined income of £60, for a four times mortgage (if they can get one….) makes £240k. Which is significantly short of a majority of house prices in a lot of areas. So instead they’re forced to rent a place for £1k+ on which the LL has mortgage repayments of £500 - it’s an ever decreasing circle for the tenant. That’s simplistic, I know, but neatly sums up the problem.
Some good points there, for sure. However the rental market is going through considerable upheaval with many private sector landlords leaving the sector due to numerous legislative changes, thus the stock of available houses is dwindling. It's fine for the person who inherits a flat and sticks it on AirBnB, collects the cash and lives a happy life. Not so good when the proper landlord has to get through registration, electrical and gas safety, fire and smoke alarms, ISITEE, legionella risk assessment and of course there isn't the same mortgage relief as previously and there is the extra stamp duty too. etc. Many do, of course, but these hurdles are seen as burdensome and expensive for many rogues, so they just don't bother.
It's a huge debate, but I'm just going to --- that AirBnB and their like have skewed and screwed the rental market not just in the UK but in other countries too, and I can't see things getting any better.
Then what you’ll find is that the LL has a case simply to withhold the deposit! I get that this is an emotive subject but you really need to stick to your field of expertise - we all do in everything - otherwise something will come unstuck.
Thats not even protected ...again...stay on the same page . The landlord is going to ROYALLY screwed . And deserves to be .
Luke, slightly combative reply here? A) This is new information and B) still doesn’t really change the narrative - I’d suggest that the only advice you should be giving is simply to get advice, otherwise you’re putting yourself in the firing line at the same time as acting as judge and jury based on armchair warrior law. Which isn’t to say that the whole situation doesn’t sound like it stinks from top to toe.
Read it again...they are leaving in October .What could a landlord do ? 2 months notice , then 3-5 months .Thats if its all legal
He can start legal action which can result in them being prevented from leaving the country.
He really would not want to be going near a court !! He cheated and put their safety at risk.
That is a seperate issue, non-payment of rent is an issue that the landlord can take action against the tenant for.
Safety failings are seperate issue that the tenant can take action against the landlord for.
He deserves to lose the rent .
That's not your decision to make.
And should be reported on the day they leave .he needs sorting out
Anything which needs to be reported should be done in a timely manner. Deliberately waiting until the day they leave will again harm the tenants case in this matter.
There is a clear cut procedure in place for dealing with an unprotected deposit, the tenant simply needs to follow due process and can be awarded up to 3 months rent (possibly more).
Of course if they going in to this with your aggressive and combative attitude it will again harm their case and help the landlord to fight back.
They walk away with more than £10k.... he expects this as rent from now till they leave . His hard luck . Game set and match . And he can go and get the money from them if he wants ..trouble is where they are going , he wont be coming back in one piece !! And no Dave,... they can leave the country any time .The law is very different when it comes to civil matters
Of course not, tenants don't complain because we know that complaints = eviction.
Not always.
A good landlord will listen to tenants, or not have complaints in the first place
We’re going round in circles, with half of us saying landlords are evil, and the other half…. Who have real life experience of being a landlord, saying otherwise…..
And refusing to pay rent because something hasn’t been done is the the same misled mentality of turning up with a couple of pals and baseball bats at the door of a customer who hasn’t paid you.
There are official ways to do things, that doesn’t involve breaking the law yourself.
Not always.
And those methods take time and money .Life is too short .Sometimes you just have to play dirty .Especially when there is zero they can do abou it . This country is a mess due to the last 25 years housing crisis . Greed and lack of concern from councils
There have been some wild sweeping comments on this thread.
With the state of some EICRs recently some people might say all electricians are cowboys. I'm sure you wouldnt agree with that though.
It's not good getting angry and letting emotion win over sense.
For disclosure, I have been a landlord for around 15 years. My tennants have never had any issue that haven't been sorted promptly. On the other hand I had one lot of bad tennants to deal with.
Landlords are people as well, they just want paying for a service they provide, they have invested in a property and offered it to others to live in, if you truly believe your LL is a rouge, move.
Its Often not an easy decision to make.
For instance, I have a family member who is renting a house for him, his wife and 2 children (one of which is seriously special needs)
The state of the house is poor but not terrible
they have been trying for weeks to get a faulty tap fixed but no assistance so far, constantly leaking onto the counter then onto the floor where they are mopping it up regularly.
the electrics are a mess, whole house is on a single 30mA rcd that has been bypassed by 2 loops of cable from intake to output.
Obviously as I am not within a part P scheme, i have not disconnected the loops to see if the rcd is faulty or if there is a genuine fault but my "expert visual analysis" leads me to suspect a fault with the house wiring.
If I were to write up an EICR for the property it would be marked as UNSATISFACTORY.
they have no recent gas cert, no electrical cert, however the the landlord has made it clear that any troubles with the legal side of things will lead to the house being sold.
they cant afford to move so are therefore Fooked or other word that sounds a little like it.
Its not easy for people renting, some landlords are just not doing what is required of them.
I understand that some landlords are also having trouble with tenants so its not all one way, a proper legal structure that regulates landlords and tenants would possibly be a step forward but all the bad ones would avoid registering.
And it will be getting worse ..... Sometimes you have to fight fire with fire .
Have they/you spoken to shelter about this?
They may be able to offer some help and advice.
If they are within the fixed term of their tenancy then it may be that any sale of the house just transfers the tenancy to a new landlord and doesn't result in their having to move.
There's a lot of if's but's and maybe's to it all so proper advice is needed.
Reply to Rogue Landlord Encounters in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
