Roller Shutter issue | on ElectriciansForums
Discuss Roller Shutter issue in the UK Electrical Forum area at ElectriciansForums.net
BB5 4HH
I hope this is the correct place to post
I have a external electric roller shutter. it was working fin until last week my son accidentally gently reversed in to the shutter whilst it was opening. no visible damage ie bent slats etc
Now it does not fully open stops 2 ft from fully opened. iv tried forced pushing it whilst opening still stops 2ft from fully open.
What i have noticed when fully closed the slats looking at the roller box the slats are at a angle not level to the roller box if that makes sense. one end is higher that the other i dont know if that is the problem causing not to opening fully.
I have took the roller box off drilled the rivets. the bar of the shutter are going into side runners with a bolt. I was thinking of undoing the bolt from one side and manually rolling the shutter until the slats are parallel level with the shutter bar rather than being angled
any advice please will be much appreciated
Yes Please see below. See if it makes sense
  • [ElectriciansForums.net] Roller Shutter issue
Reply to Roller Shutter issue in the UK Electrical Forum area at ElectriciansForums.net
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
