L
Lex
Hey guys, I could do with some help.
I'm out doing a job and the site im working on has two buildings, both have a roof mounted exhaust fan for the toilets. Either is working. I've checked and they both have a supply. I have a little experience with motors but not enough for this kind of fault finding. each has 6 pins, the top two are linked, the bottom left hand pins are link as are the bottom right hand set. between the middle two there is 240v, between the bottom 2 there is 240v. between the top left hand pin and bottom left hand set is 287v, between the top right hand pin and bottom right hand set is 187v. as shown below (roughly)
Dont know if you can actually see that
any advice on how to get them running would be greatly appreciated
