roof surveys | on ElectriciansForums
Discuss roof surveys in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
fareham
Hi,
Am preparing for first install, Do you have to have a roof survey carried out on each property before installing onto roof?
I was wondering because if the assessor asks how i knew the roof was structurally sound i couldn't answer how!
We have a structural survey undertaken on every job we do - it's the only way we know a roof is up to taking the load and if Mr. MCS asks, we can show him the evidence. I am fairly sure we are in the minority if what we hear about our competitors is anything to go by.
Who do you use? and what level of check do you have? do you send them photos of the roof or do they actually climb in the loft and survey?
I was thinking of using the roof survey scheme through napit.
We've been using Curtins. I think they have a few offices around the country. They prefer to visit site and climb in the loft themselves. We get a quick answer over the phone usually later the same day, followed up with a comprehensive written report.
Reply to roof surveys in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
