Roofing bolt screwdriver | on ElectriciansForums
Discuss Roofing bolt screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
edexlab
Uk
Morning all ,
I've seen a few threads about roofing bolt screwdrivers and thought I'd share an idea I've been using,
All it is , is a bit holder handle and a modified spade bit with hex /bit driver end this was a CK bit. ie cut to shape with a grinder
[ElectriciansForums.net] Roofing bolt screwdriver
Reply to Roofing bolt screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
I would say it is more about the bits than the torque of the drill. I use high quality Fisch auger bits for drilling out mortices and peg holes...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
