Rookie electrical question | on ElectriciansForums
Discuss Rookie electrical question in the Australia area at ElectriciansForums.net
P
petewillclarkso
Hi,
I bought a PA amplifier today, but it didn't come with a power lead. I didn't give this a second thought as I have many leads knocking round, and knew I had one that fitted the socket.
But completely by accident, I noticed that the markings on the plug say 250V, and the socket on the amp says 240V.
Would it be safe for me, and the amp, if I use this?
I am no electrician, I know squat about all this, but I haven't been able to find an answer on the intenet anywhere.
PC
Shouldn't be a problem.Electric supply companies allow +10% or -6% of a nominal voltage so they say.Voltages today are usually 230V single phase and 400V three phase.Hope this helps.Paul
Hi
If the lead fits into the PA the size is usually okay but check the fuse in the plug it should be close to the amperage on the details on the amp. If it states 250v that's usually the voltage range, when it states 240v its usually old equipment, we now use 230v so the voltage is okay for all of the above voltage range is commonly 220v to 250v.
Regards
If the input on the amp is a normal three pin (computer lead type) then it's best to use a normal 3 pin plug as some continental plugs don't have any earth provision. The earth protects you and the amp.
That's okay, my deep fat fryer has the same input, with a UK plug. I'll just swap them, Id sooner blow that than my PA system! :)
Thanks!
Best find another lead. The 2 pin plug on the fryer isn't a good idea either, again no earth. You could kill yourself using a fryer with no earth, but then you'll maybe kill yourself first with the deep fried grub, LOL.
Those leads are easy to come by, I throw dozens of them out all the time.
Reply to Rookie electrical question in the Australia area at ElectriciansForums.net
