Room stat | on ElectriciansForums
Discuss Room stat in the Australia area at ElectriciansForums.net
sparkz
MCB trips out when room stat is turned down. What could this be?
Honeywell stat that controls the central heating powered from a combi boiler. Its a neighbour, the stat was working fine untill it smashed off the wall. I told him to replace with a new 1 but its still trips the mcb when he turns the stat below 25.
Reply to Room stat in the Australia area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
