You can also get programable thermostats that allow different temps to be set at different times of the day,ie set cooler when moving about in the day and warmer first thing in the morning or evening,when sat about,these type of thermostat's can bring a nice saving on your fuel bills :stooge_moe:
"Hello puddle",
That is one of the Best Money Saving Tips that you can give regarding Heating Controls.
Programmable Room Thermostats can be Set for up to 8 Different Timed Temperatures per Week - depending upon the Manufacturer and Model.
I have mine Set to:
Program 1: 23 Degrees at 05:00 Hours for Monday to Friday
Program 2: 18 Degrees at 08:00 Hours for Monday to Friday
Program 3: 23 Degrees at 17:00 Hours for Monday to Friday
Program 4: 18 Degrees at 00:00 Hours [Midnight] Monday to Friday
Program 5: 23 Degrees at 05:00 Hours Saturday
Program 6: 18 Degrees at 00:00 Hours [Midnight] Saturday
Program 7: 23 Degrees at 05:00 Hours Sunday
Program 8: 18 Degrees at 00:00 Hours [Midnight] Sunday
You can also Over-Ride the Set Temperature with the Press of a Button - to Lower or Increase the Thermostat Setting - this then changes back at the next Time & Temperature Setting.
THESE TEMPERATURES ARE OBVIOUSLY A PERSONAL / FAMILY CHOICE THING - NOT WHAT I WOULD SUGGEST TO ANYONE ELSE TO USE.
As You can see it would be better if there were more Time and Temperature Settings to be able to Set more Weekend Days Timed Temperatures - But 8 Settings seems to be the Norm for some reason.
A Pity - as I have Security Light Switches that allow up to 42 Settings it is obviously easily possible to manufacture the Programmable Room Thermostats with more Settings available.
Installing a Programmable Room Thermostat can enable the Householder to make considerable savings on their Gas Bills and I would always suggest that I include one as part of the Heating Controls on any Heating System that I Install.
These do need to be explained to the Client in a bit more detail because they can be confusing to Set Up and Temperature Over-Ride if not explained correctly.
Because I had planned to Move My Home`s Boiler during last Summer I had not gotten round to Installing a Programmable Room Thermostat previously - I ended up Fitting a New Programmable Room Thermostat in about the end of November [?]
Although We have had a Very Mild start to Winter this Programmable Room Thermostat has made a BIG difference to My Heating System Gas Usage.
Because of the Mild Winter Temperatures that We have had when My Room Thermostat is Set at 18 Degrees during the Daytime it often Stops the Boiler Firing for up to an Hour at a time.
puddle - Although I `Addressed` this Post to You - I have Posted these details in case that they might be Helpful to other Members / Guests on here - As You are a Heating Engineer You will already know all of this.
Regards,
Chris
