On a standard combi boiler with a roomstat fitted when the temperature falls below the set temperature the boiler fires up and brings the room back up to temperature. Correct
On a system boiler say a y plan for example the call for heating or hot water comes from the programmer when selected by the user. Correct
If the programmer is on but you are not calling for heating or hot water do the stats spring into action if the room temperature falls below the temperature on the stat or the temperature of the water in the cylinder drops below the stat temperature setting?
Just a little bit unsure so if anyone would like to comment then feel free
Thank`s
Thank`s
