Can you come off a 45amp rotary isolator to a fused spur to supply a feed for an out side light???
the Rotary isolator is supplying a hottub and is run in 6mm SWA witha 32amp rcbo???
Not sure if i can come off it or need to run a new feed!!!
Any advice would be great help!!!
Thanks!!
Thanks!!
