Doomed
A customer has a light fitting with a round base that is designed to be mounted on the cieling.
She wants it on the wall.
The mounting holes on the fitting will line up with a standard patress, but as it is a round base the corners of the patress will not be covered.
I considered a galv end piece, as the fitting could be 'encouraged' to fit this as well, but as the galv mounting points are not horizontally in line with each other this will make the fitting look pants.
My pride stops me being really rough and simply channelling into the back of the fitting.
Any Ideas.
Doomed
Dorset
Round metal patress
Australia
Doomed,
dim_bulb,
