L
LOYDE
Hi all,
Am new to the forum so hope I've posted correctly.
System 1966 lead TN-S
Am about to move cu to new location, concrete cavity wall with meter box on outside.
Intend to route 25mm tails + 16mm Main bonds through wall via 50mm steel trunking to cu and main earth to met (in meter housing).
Am happy this will comply with additional protection regs but am worried about thermal bridging of the cavity and the potential for a fire to whip up/or through the cavity.
Would it be acceptable to fill the section of trunking that bridges the cavity with a fire block type expanding foam?
My concerns are de-rating the meter tails and need of if not needed, as client is already upset he can't just move the meter by uncovering incoming main and literately dragging cable + meter and all to new position!!!!!!
