Routing of 'Main Bonding Conductor' | on ElectriciansForums
Discuss Routing of 'Main Bonding Conductor' in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
W
WayneL
Hi,
I'm replacing a Main Bond to Water which needs to run across a kitchen.
The ideal route would be straight across the floor because, at the moment, it is yet to receive a final 'skim' of 50mm and will then be tiled over.
Is it acceptable to run it like this - which I suppose is similar to running under plaster in a wall - or is it required to have mechanical protection?
Cheers
for what it costs, i would run it in 20mm pvc conduit. mechanical and chemical protection, and rewireable
Yeh, that's possibly the best option - and as you say, not expensive.
I know the 'Regs' refer to buried 'Earthing Conductors', I just couldn't remember if the requirement extended to 'bonding conductors'.
Reply to Routing of 'Main Bonding Conductor' in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A lot of external bonding or earth conductors are bare copper strips. If mechanical damage is likely, then run some steel conduit… but all UV...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
Recommended Sponsor News
Hi everyone,
