rs232 to usb lead | on ElectriciansForums
Discuss rs232 to usb lead in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
poheZ
Hey
Has anyone manage to get one of these leads up and working to communicate with the edge inverters?
I have a cable and i downloaded a driver for this but it still wont recognise the connection coms when connecting with the configuratirs software, any tips?
Do you mean a USB to rs232, for computers thar do not have a rs232 built in.
If so installing one of these should create a virtual com port when connected that will show up in device manager as COMn (n being a number) there should be a way of selecting the COM device in the software and setting the baud rate etc.
Also you have to watch out with some of these, if you plug it into a different USB port next time it installs as a different port number. So try to always use the same USB port.
Yes, sorry
I thought i installed a driver but i cant find it in device manager (i presume it will under ports?)
If you are able to find me a driver that would be great..... seems to be a bit more complex than installing a printer!
When you plug it in what name does windows show for the device. Also driver depends on version of windows and if it is 32 or 64 bit.
I have installed it but it failed on installation and now under driver status in device manager it says driver cannot start code 10!
any ideas?
Reply to rs232 to usb lead in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
That worked!!! Thanks again for all the help and responding so quickly. Really appreciate it!!!
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
