Rubber matting | on ElectriciansForums
Discuss Rubber matting in the Commercial Electrical Advice area at ElectriciansForums.net
SCOTLAND
a guy has coded a 2 on eicr for not having rubber matting at DB's this is a school, is there a reg out there to back this up
not that i'm aware of in BS7671, however, the local education authority might have their own H&S policy relating to this.
I have seen rubber flooring in switchrooms many times before, but generally only those that contain HV.
In a school I would maybe expect to see it in the room that housed the incomer and MCCU arrangements, but not usually in any sub-DB room.
Academic anyway as it does not feature in BS7671 and should have no place in an EICR.
HSE only mention it , page 2 top right;
http://www.hse.gov.uk/pubns/eis37.pdf
Insulating rubber floor mats, eg in accordance with BS EN 61111 can be used to prevent earth contact with the floor.
However, they will not provide any protection if a person touches the large metal areas of the control panel simultaneously with exposed live conductors which are likely to be at earth potential and readily accessible.
He must have slipped on his --- and banged his head to come out with that one...
Reply to Rubber matting in the Commercial Electrical Advice area at ElectriciansForums.net
im just assuming that they are designed to be surrounded by material, and would heat to a certain amount, spreading the heat into the material...
1.2 x 1.2m large format tiles & Decoupling Mat? Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
