M
mr7526
Hello all,
I am currently looking to install a new socket in the hall, spurred off the ring main. The socket will be installed in a stud wall.
On the other side of the wall is our downstairs toilet and then the garage (where the easiest access to the ring main can be found). However, running a cable to the garage will either involve running a cable along the top of the skirting board or around the top of the wall. Ideally, I'd like to run it along the skirting board, but this will take me past the back of the toilet. Is it acceptable to run T+E past the back of the toilet?
Also, is it acceptable to just use cable clips or should I use conduit (not a fan of conduit, TBH)? Is it better to put an FCU in the ring main or to just spur off with a junction box?
I can't pull the floor up and run cables under it because it's covered in Laminate.
Many thanks,
Matt
Many thanks,
Matt
