F
Frogwell
Morning all, First time post here although I've lurked about a bit before looking up information on how to do stuff without overly killing myself.
Living in a rather exposed location on the side of a hill, we tend to have a little more than our fair share our electricity cuts in winter, which never used to be much of a problem when the central heating and water came from the coal stove. However, a few years back I replaced the stove with an oil fired Worcester Bosch combi boiler and now enjoy staggering heating costs, a much colder house and no heating or hot water when we have a power cut. To address the power cuts, I was thinking I could probably use my 2.6kw generator - it would seem to be the logical option. Does anyone know if it's just a case of cutting the main power cable to the boiler, sticking a plug on it and then plugging it into the generator when the power goes off? Or is there more to it than that? I'm assuming the thermostat and control panel for the boiler take their power from the boiler, or do they? Would I need to connect them to the generator separately?
There's also the question of voltage regulation, I know the boiler has an electronic control panel as it needed replacing twice within a month of being installed, but how sensitive are they do the potential fluctuations from a generator? Although presumably just using the computer UPS would sort that?
Obviously the ideal solution would be to have a transfer switch installed by the main electrical panel, but switch cost plus a days work from an electrician put that North of my price range.
Thanks.
Thanks.
