running a house from car batteries for the electrical idiot | Page 5 | on ElectriciansForums
Discuss running a house from car batteries for the electrical idiot in the The Welcome Forum area at ElectriciansForums.net
Ah, tongue testing batteries...it's like other things...you know you shouldn't really...but you go ahead anyway!
You mean like Mc'ewans Ale?
Aye, McEwan's Pale Ale...available from my local C0-op when I was a teenager at 8p/can! ...and that's where the rot set in...
Remember the 1289? Used in those flat torches and also in the lamps on your bike?
Also used in the Electronic Engineer kits (anyone remember those?). You could build a radio or an alarm etc, putting the components onto a perforated board with spring-clips.
OP DC is the future, as already suggested; make sure your using LED lamps, the 12v twin pin MR16 ones will be most cost effective. I’d also suggest you get a deep cell leisure battery rather than using a standard car starter battery. Also, don’t try using this system for any space or water heating, low load applications only. Good luck.
Reply to running a house from car batteries for the electrical idiot in the The Welcome Forum area at ElectriciansForums.net
I have an AC system that is not working. All fuses and relays tested successfully. Blower comes on, but blows hot. System is completely empty...
What you're trying to do here is break the first and second laws of thermodynamics which, of course, is impossible. There are always losses in a...
    • Optimistic
