J
johngiowa
Hi,
I'm trying to devise a solution to a problem. Basically I'm looking to mount a chain driven system to the side of a car to move an item up/down and away from/towards the car. I was trying to do it hydraulically, but that's starting to look too hard.
I'm trying to find out what the largest electric motor I could run off a cigarette lighter is and if it would be strong enough to lift approx. 5kg of weight. I don't want to blow fuses or drain the battery. The car (turbo diesel) would be running whilst in use.
And just to make things more complicated ideally it would be waterproof.
Is someone able to point me in the right direction? Even if its too the funny farm - just trying to see if this is realistic.
John
John
