Running Aluminum URD Cable | on ElectriciansForums
Discuss Running Aluminum URD Cable in the DIY Electrical Advice area at ElectriciansForums.net
danrud
CDA
Hi, I am burying wire from the outside meter panel to the new 100amp sub panel inside a garage. The run is 20' long. Is 2-2-2 Aluminum URD Cable good enough or do I need the 4/0-4/0-2/0 Black Stranded Aluminum Triplex URD Cable? Anyone that can answer I would greatly appreciate it.
Reply to Running Aluminum URD Cable in the DIY Electrical Advice area at ElectriciansForums.net
The power company only brings in 3 wires which is 2 live and 1 neutral wire. It’s our responsibility to add the ground rod to bond the neutral...
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
