Running branch to shed | on ElectriciansForums
Discuss Running branch to shed in the UK Electrical Forum area at ElectriciansForums.net
north florida
I want to do a run to a subpanel in a shed - about 50'. 3 circuits: lights, electrical, spilt. I have an isolation panel - can this be retrofitted with a subpanel circuit to branch off to the shed?
  • [ElectriciansForums.net] Running branch to shed
You are not allowed to add or change anything in that panel. It looks like an Eaton meter base/ main breaker combo and in this picture you have no way of installing a main breaker to feed a sub panel
thanks for that. So full run to main load center - not a problem, a little longer run but easier in some regards. Appreciate the advice!
Reply to Running branch to shed in the UK Electrical Forum area at ElectriciansForums.net
BTW, the LD at the house will be 1" to accommodate the 6/3 coming from the house. Will use a 1" to 3/4" adapter to neck down to the 3/4" conduit...
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
