Running cable in plasterboard | on ElectriciansForums
Discuss Running cable in plasterboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
gafin
Hi All,
Question for you all.
Installing a heated bathroom mirror in a bathroom in a mid terraced house, I've drilled into the plasterboard (1/2" thick) to find it lays directly on the breeze blocks and there is no void.
What would be the best way to run the cable up to the loft above the room.
Cut a channel into the plasterboard, run the 1.5 T&E in and then plaster over it, or.....
Install a section of conduit on the wall down to the light? Would have to be steel to go with the chrome in the room!
Your thoughts and feelings are appreciated............
It is quite a good idea to install a bit of small oval so that when you come to install it you just push the flex up the tube stick your mirror back and then connect the cables in a JB in the loft
I assume the bathroom is upstairs, If I push a terminal screwdriver thro the ceiling where you intend to put the fitting go up into the loft and locate the screwdriver and then drill down using something like a 10mm drill in the wall, Measure how far down you want to be and mark the same distance on drill with tape. go back down into bathroom and drill into the wall SLOWLY and with a bit of messing around you will locate the hole you've drilled down. Easy as that and no plastering just a bit of hole filling which most of us can manage. I thank you!!
Hi all,
Thanks very much for all the replies so far... I brought some 16mm oval conduit (the smallest I could get) but it doesn't sit flush with the plaster so I don't think the conduit approach will work...
How wrong would it be to put the twin and earth in the channel I've cut out and just plaster over it? Could anybody see any issues with this?
I know I will have to put the lighting circuit on the rcd side of the CU under the 17th.
I only have 1/2" of plasterboard before the breeze blocks, and 13mm capping is just over half a inch before any plaster so would leave a raised strip after plastering....
Capping achieves nothing other than conveniance and protection against the plasterers trowel
Bury the cable directly under the plaster by clipping against the breeze wall
Reference method would then be C Clipped direct in masonary wall
Hi All,
Don't forget it will have to have an RCD protecting it as it is less then 50mm and also in a bathroom which is a special location which also will require notification to the LABC.
Reply to Running cable in plasterboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
And if it's a garage then use metal clad accessories.
