Discuss running cables in ceiling in the Talk Electrician area at ElectriciansForums.net
HI all first time poster here anyway ,what is the best proper way to run cables in ceiling before the plasterboard goes up ,drill the joists or just clip them to the top of the joist, thanks in advance.
Sort out your cable route first!!! then use a 32mm wood bit to drill your holes as close to the centre of the joist as poss. The holes will need to be at least 50mm from the top or bottom of the joist in order to prevent nails from going though the cable.
Reply to running cables in ceiling in the Talk Electrician area at ElectriciansForums.net
