Running cables underfloor | on ElectriciansForums
Discuss Running cables underfloor in the Australia area at ElectriciansForums.net
Y
YTSOxford
Am having to run a ring main to an island in the middle of the kitchen and back again, just wondering if there is any regs dictating what needs to be done on this? min depth etc.
Was just going to lay it in PVC conduit in the screed.
Sounds fine mate,that's how i did my last one.Cables a bit tight thou in the 20mm conduit.As long as the cables are protected in the floor
Reply to Running cables underfloor in the Australia area at ElectriciansForums.net
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
And if it's a garage then use metal clad accessories.
