Running mdpe externally in rainwater pioe. Hi all.
Wondering if anyone has done this and if so what insulation did you use? I have about 1 metre that needs to run up from patio height to just above the damp proof course. The wras approved pipes are quite big and costly and I have lots of rainwater pipe I could use.
Cheers all.
Hope you are all doing well.
Running mdpe externally in rainwater pioe. to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Cheers all.
