S Plan Help
I appreciate your help davesparks but this forum is about helping each other and exchanging ideas. I don't know your electrical background and you don't know mine. Straight away like most people on here you assume I am a DIY'er for asking a question. I used to come on here a lot but it's these remarks what annoy me.
Circulating pump in cylinder cupboard went so that was replaced by a Plumber about two weeks ago. When pump was changed water ****ed everywhere and got onto one of zone valve which blew. He then got a second hand one from shed and fitted it. Now when he turns room stat down the heating stays on. Second hand zone valve must be faulty as well. The whole wiring centre box is broke and needs replacing. He wants to uofate update st699 programmer to a digital one. Got a complete kit for £140.
My Dads a Plumber and he's convinced there isn't one from the manufacturers instructions. I'm gonna have a visual check on it tomorrow and report back! Thanks.
thought you said your dad was a plumber?
Yea. I've managed to find the correct documentation now. There isn't a pump inside the boiler just a standalone pump in the cylinder cupboard. The boiler manual says to wire the pump direct to the boiler pcb terminals instead of the wiring centre.
yes that's right because of pump overrun to dissipate heat
Cool, easy then standard S-plan with pump overrun. What S-plan pack have you got out of interest?
edit: just seen op where it says honeywell.
The current set up he's got a Honeywell ST699 2 channel programmer, Danfoss Room Stat, 1 x Honeywell zone valve and 1 x ACL zone valve. He wants to buy a complete new control pack which we can get a Honeywell one complete with digital programmer and wiring centre for £140. Next time I'm round I'll post a photo with the state it looks at the moment. It's bodge after bodge over the years. The wiring centre has broke with no cover and with having young grand kids he wants it all making safe.
Your right there do seem to be a few annoying remarks made on this site which is why I stopped visiting for a while. Thought I'd come back to see if things are better. Seems not!
the only problem i don't like with danfoss is there time clocks just dont like the look and program of them so i just install drayton lifestyles much better and easy to change times even for the old people around :)
I don't mind them TBH, Honeywell is my 1st choice and Danfoss is my second. Whats put me off with the drayton lifestyle programmers is ive Been out to a few faults where Drayton has been installed and both times it's been the programmer sticking on. Saying that though I know British gas use Drayton lifestyle programmers marked up with their own logo so can't be that much of a common fault other wise they wouldn't use them.
