A
akcorbin
Hi guys, just recently wired up an s plan plus system however, the third valve is for an underfloor heating system which has its own pump, what i want to know is how do i connect this pump into the system? My switch lines for the 3 valves (orange) are connected up to the switch line from the boiler but i do not want the underfloor heating pump to run when the other two valves are called for which is what it is doing at the moment obviously because the 3 oranges are all connected. I did think of putting the underfloor heating valve in a separate connector with the live from the pump but doing this would not call the boiler for heat and if i did put a link between the boiler and the new connecter then the other valves would still become live wouldnt they?
Please any help would be grateful (if you can understand lol)
thanks
Adam
thanks
Adam
