S Plan Plus - Wiring Diagram | on ElectriciansForums
Discuss S Plan Plus - Wiring Diagram in the Central Heating Systems area at ElectriciansForums.net
stevo23777
Hi Guys
I currently have a combi boiler with a single prog stat wired direct to the boiler. I am putting in UFH in my kicthen diner and have to zone off using an S Plan Plus config. I have a Worcester Bosch boiler. I have drawn up the attached wiring diagram, would anyone be able to verify if I have made any drastic mistakes (I don't have a HW cylinder).
Many Thanks
  • wiring diagram.pdf
Hi Please find updated diagram, (correctly changed returns from zone valves to be orange), also the UFH system has a manifold mixing pump, I have added it here at the point the stat engages, I thought about adding on the switch live return from the UFH zone valve but this would mean the pump would also engage if the CH came on also, am I right in my thinking?
  • wiring diagram_1.pdf
Hi All
I have updated diagram changing colour of wire on switch return from zone valve to orange as it should be; I have also added the UFH manifold mixer pump, I am running it off the UFH stat switch live so it should kick in when the stat fires, is this correct?
Hi Guys
Many Thanks
Two port valve= grey permanent live which connects to LS on boiler, brown Connects to SL (A1)of thermostat and orange connects to LR of the boiler.
What about the manifold mixing pump, should this connect to SL(A1) also? I guess if it is on LR circuit it will engage when central heating is also which would ne a no no.
Reply to S Plan Plus - Wiring Diagram in the Central Heating Systems area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
