Hello everyone!
Have 2nd fixed a S plan System this afternoon which doesn't seem to be working correctly....
The HW is switching the boiler on fine, but CH isnt firing the boiler although it moves the valve as if it should be.
I'm not getting any return live on the CH 2 port valves's orange cable when the stat is calling and have 230V both side of stat which i have proved is going to the brown of the valve flex.
The Valve is switching over when the stats calling but it doesn't fire the boiler, HW has been working fine so i swapped the two valves over and the problem still occurred on CH (proving its not a fault with the valves so ide of thought?)
I've gone through all the wiring and it all seems correct, I've tested that the programmer/stat is switching correctly which they are so this has left me stumped!
Hope someone can shed some light on this.
Many Thanks.
Many Thanks.
