SABERTOOTH V1.03 - simple car-robot | on ElectriciansForums
Discuss SABERTOOTH V1.03 - simple car-robot in the Australia area at ElectriciansForums.net
G
girlygirl
Hello Experts,
I've got problem with my project. I want to create a car which can stand on the rear wheels. I've tried for a long time but I'm stuck and I decided to ask you for help...
Firstly I want to run my car - using all wheels - and it's my main problem
Unfortunately I have no idea how can I connect all of this parts.
I made a photo - SABERTOOTH V1.03
I connected wires (red circle, 1st picture) with motors(blue circles, 2nd picture):
http://oi41.tinypic.com/292748l.jpg
http://oi44.tinypic.com/9znmg9.jpg
My car doesn't run (all of wheels are blocked when connected to battery).
Any ideas?
Thanks in advance
Reply to SABERTOOTH V1.03 - simple car-robot in the Australia area at ElectriciansForums.net
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
