Safe isolation in the TN-C-S world | on ElectriciansForums
Discuss Safe isolation in the TN-C-S world in the UK Electrical Forum area at ElectriciansForums.net
pc1966
V.Nearly Esteemed
Dundee
While reading the IET articles there was one on the open PEN risk and now the DNOs are adding another step to "safe isolation" where they clamp the earth bond to check if there is diverted neutral current present before disconnecting anything related to that.
The youtube video for this:
TL;DR Get a clamp ammeter and check ALL cables you plan on disconnecting!
Who said a non contact voltage indicator had no use :)
Yes, that was a surprise but equally it makes sense!
Of course it is more one of confirmation of polarity and metalwork being at earth potential, but certainly anything that makes you think "oh, that should not be happening?" is worth having for the rare case you come across a potentially dangerous system to isolate or (possibly worse) a dangerous "dead" system to be connected back up.
Part of the process for opening street furniture (G39) is to check using a voltage pen. You can get proving units for them but I use the Martindale TEK200 which has a built in test facility.
Reply to Safe isolation in the TN-C-S world in the UK Electrical Forum area at ElectriciansForums.net
