safe isolation on a wylex db? | on ElectriciansForums
Discuss safe isolation on a wylex db? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
matt456
how do you do a safe isolation on a wylex rewirable type db? the rcd is seperate in an enclosure dont think i can lock it out as it is the revolving type?
Do i just remove the fuse and put in my pocket as this is a jobe for my niceic inspection and he may want to see me isolate etc.
Reply to safe isolation on a wylex db? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
even allowing for diversity this sounds a bit tight for a 100 amp supply, can you tell us what the existing circuits actually have connected to...
Yes like that - fitted last week 😂
