Safe isolation question? For three phase | on ElectriciansForums
Discuss Safe isolation question? For three phase in the Electrical Course Trainees Only area at ElectriciansForums.net
Adam_92
Trainee
luton
hi, I’m wondering if there is a safe isolation sequence obviously first steps are:
Ask to isolate
Lock off and put up signs keep key safe
Then prove leads working on proving unit
Do the 10 steps- (do you have to do these in an exact order?) some tell me no and some people say yes
Back on proving unit
This is quite good.
[ElectriciansForums.net] Safe isolation question? For three phase
Hello Adam I have moved this to the Trainee section to prevent irrelevant posts. If you have any questions along this line in the future the Trainee section is the best place for them as access is restricted.
Ask to isolate
That's not really a good video. Many mistakes that would get picked up on an AM2.
Firstly he should point out never remove the front cover until the main switch is turned off and the lock is in place.
Secondly it's good practice to turn all circuits off individually before the main seitch (not sure if its something that would be deemed a failure)
Thirdly and most importantly, never put a the probe on a live conductor then the other to earth/neutral. Always put the first probe on the conductor with the least danger first. This is an instant fail as far as I am aware.
It is C&G and EAL approved
Reply to Safe isolation question? For three phase in the Electrical Course Trainees Only area at ElectriciansForums.net
