Safe system of works around pv array | on ElectriciansForums
Discuss Safe system of works around pv array in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
North Lincs
Due to an incident of an induced voltage on the array framework and someone getting a shock what’s people safe system of works in place to minimise this happening ?
Is the issue of bigger concern not the stray voltage on the panels?
Have the panels been checked they are meeting design specification for insulation resistance?
Should the framework be earthed to avoid this?
Was the person who got the shock an innocent bystander or someone working on the array?
If it was someone working on the array were they suitably experienced and or supervised?
If it was an innocent bystander then a suitably experienced person should be investigating and should know the Safe system of work and be able to diagnose the fault and fix it.
Untill that happens then access to the array should be restricted
Due to the OP only ever making this post and not coming back I don't think this is going anywhere.
Reply to Safe system of works around pv array in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
Hi everyone, I work for a team called Greenworkx, where we help people get into green careers by offering training and job opportunities. One of...
