Safety circuits safe or not?? | on ElectriciansForums
Discuss Safety circuits safe or not?? in the UK Electrical Forum area at ElectriciansForums.net
P
Paul Osman
Hi, Recently whilst investigating a fault on some equipment at work I noticed something I was unsure of about two different safety circuits.
Machine 1. (Elevator control panel)
All the safety elements (2x Door Switches, 1 Estop button and 3x Pull cords) are connected in series to the coil of a general purpose relay (Omron MY4). Then 2x NO contacts of the MY4 are then monitored by the safety relay. Surely a fault with the MY4 would then render the safety elements useless?
Machine 2. (Elevator control panel)
All the safety elements (4x Door Switches, 1 Estop button and 3x Pull cords) are connected in series to the A1 (24vdc) power input of a pilz safety relay.
My understanding and examples of safety circuits I have looked at have the safety elements monitored. I was just wondering if anyone had seen these types of configuration and why they are done like this.
Depends, in machine 1 is the supply to A1 of the safety relay (which as you suggests runs through 2no N/O contacts on the MY4) broken by the action of the aux relays alone or will operating any e-stop functions cut its power. What i mean is if the contactor jams in does operating an e-stop break the power supply going through the aux' contacts or have they got a maintained independant supply.
Also would need to know the safety relay type as they operate in different ways most have maintained power with monitor channels although i suspect not the case here as it drops out on power loss, more info please... plus do you know what safety cat' the machine is?
Reply to Safety circuits safe or not?? in the UK Electrical Forum area at ElectriciansForums.net
