Sangamo timer clock not working | on ElectriciansForums
Discuss Sangamo timer clock not working in the UK Electrical Forum area at ElectriciansForums.net
rolyberkin
Nearly Esteemed
Chelmsford
I have a client who has one of the below, I have never worked on one. He states that it is not switching on the lights although the emergency light part of the lighting is apparently being charged, he has re set the timer etc. Does anyone work on these a lot and is there any quick solutions or probable likely causes before I drive out to it please?
Ta
Q553 Suntracker - https://www.sangamo.co.uk/collections/round-pattern-time-switch/products/q553?variant=41085931270
manually turn the dial and you should see and hear it switching.check for volts on the output side. also, check to see if the clock is actually running.
Reply to Sangamo timer clock not working in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Ah OK, that makes sense. Thank you Avo.
