satellite cables | on ElectriciansForums
Discuss satellite cables in the UK Electrical Forum area at ElectriciansForums.net
Hi Y'all,
hoping someone in here has some experience with satellite feeds....
As part of a rewire i've been asked to take a satellite feed into 4 different rooms for freesat. My question is do I simply run 4 separate CT100 cables from the quad LNB on the dish into each room or do I have to take them through a multiswitch/amplifier first? or another method altogether?
longest run would be about 20M.
thanks
Check with customer first, if 4 way lnb is installed, then HD record & play boxes cannot be used as they require 2 WF100 cables per box ie 8 way for 4 rooms.....consideration for cat5 & bt cable also needs to be taken into account for pay per view and upgrades.....suggest discussing with customer first.
Reply to satellite cables in the UK Electrical Forum area at ElectriciansForums.net
Interesting item you have there. This blog might be worth a read https://sllipblog.wordpress.com/2014/04/29/its-now-00-28am-and-i-need-my-bed/...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
