SB 4000TL & Sunny Beam | on ElectriciansForums
Discuss SB 4000TL & Sunny Beam in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
saint
West Sussex
If for example, a 4kWp system was split East/ West is it possible get info from the Sunny Beam showing how each separate elevation is performing? or would two inverters be needed with separate net id's?
Cheers
Reply to SB 4000TL & Sunny Beam in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I guess the easiest way would be to run a supply from ignition /aux via a relay that drops the supply when the lights are on.
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
